1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#31256 06/21/2003 1:31 AM
I
Junior Member
Junior Member
I Offline
Ok Guys, heres a dumb question...
where do I aim the strobe light at when I'm timing the 216? I've looked all over the pulley below the fan but dont see any marks.
#31257 06/21/2003 3:33 AM
There's a hole in the bellhousing above the starter. Look for a little ball about the size of a BB on the flywheel.
#31258 06/21/2003 3:43 AM
Itza 46, timing mark is on flywheel, Kind of like porshe or audie, anyway just above starter motor is a round hole with a pointer in it , disconnect vacuum at distributor, point lite at flywheel, look for steel ball inbedded in flywheel, line up steel ball with pointer your all set, hookup vacuum , also distributor hold down is not for adjusting timing, there's another screw usually toward block you loosen, hope this helps smile
jbennett
40 burb
#31259 06/21/2003 4:44 AM
I
Junior Member
Junior Member
I Offline
Thanks Guys,
I never would have found that.
