2 members (DES57, 1 invisible), 142 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
Hum... An annoying 'wik-wik-wik' noise is coming from the drivetrain. It has a high pitch metalic sound, like a worn bearing, in the clutch area. It does NOT stop when I depress the clutch, so I'm ruling out the release bearing? It is quite noisy and getting on my nerves...
Any ideas what can cause this?
Any input would be appreciated,
thanks
whizzerick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
Good morning Rick (6 am here in Calif) eek
Do you hear it when stopped and idling ? or only when moving ?
Craig
Morning! Only when moving.
It modulates from a 'wikwikwikwikwik' to a 'wik-wik--wik---wik----wik' when slowing down...
Big Bolt Shop Curmudgeon
I don't think it is "wik-wik-wik." Yer truck is saying "quick-quick-quick fix me!" (Laughing).
Without some more information it is hard to diagnose noises, he** I can't even diagnose my own.
Could be:
1. One thing scraping on another, like a brake shoe, tire contacting something, spring in the seat bouncin' up an' down.
2. Bearing noise can be almost anywhere--front, back, drivetrain, etc.
If you hear it at slower speeds (10 to 15 mph) maybe have somebody ride in the back (or let 'em drive, if you're not afraid). Try to pinpoint the location.
If you have GOOD, DEPENDABLE jack stands, maybe try raising the rear wheels. Unfortunately, some noises go away when there is no load. Just don't crawl under the truck up on jack stands when it is running--ever!
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
Whizzer: Good to see ya: Sounds like your clutch plates are getting worn. Does it shift alright or grind when shifting, clutch pressure on pedal Ok or does it feel weak, I agree with Glenn put it on stands let it idle and put it in gear. Isolating is your biggest problem. popcorn
The Truth is Out There (I have to smile every time I see a motorized bicycle) Ben
Yes, the clutch is likely the culprit.
I have access to an alignment lift (a very safe lift for that kind of diagnosis), I'll keep you posted on my findings. Thanks!
rick
IS this only when moving?
If so, it will be something inside the tranny or at the rear of the tranny or back toward the rear end.
Could be a wheel bearing/seal/dust-shield,,ANy recent work on the wheels???
Have you trued disconnecting the speedo cable from the tranny and then drive it to see if the noise goes away?
Whiz, what is a 53 1300, is that a half ton? just turn your radio up and the noise will go a way, that will be $1000 just because you are my friend,,,,,Fred
Redryder pix
My Hotrod
Mechaniac,
it is only when moving. I have replaced the front-right-outer bearing and will replace the inner tonight. I am almost sure that it comes from the transmission area, though. Now may be a good time to take out the trans, replace the rear motor support, check the clutch and replace the leaky rear main seal.
I wish I could have waited till winter...
Joker, now I know where you got that surname... :rolleyes:
dumb question and a thought
could it be the speedo cable , my made sqeeking noises and a few drops of lubricant solved the sqeek.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
I vote for pilot bearing.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Fritz, that's interesting as my speedo stopped working a while back. I'd have to check that out BEFORE attacking the trans. Thanks for the 'heads up'.
rick
Mechainiac
Stovebolter # 930
posted 08-05-2003 05:31 PM
"Always use the word "Impossible" with the greatest caution"
Might look up a few posts LOL grin
Woa! I missed that one Mechainiac! Thanks!
I guess I was blinded by the idea of having to remove the trans ans clutch... I'll keep you posted.
rick
No problem, Fritz had you covered cool
I highly suspect the speedo cable since you stated that it quit working awhile back smile
Disconnect the fitting at the tranny(rear)and see if the noise goes away(eliminate the simple things first)
Well.
I just got back from lunch and before leaving I took the large 'floor section' out, leaving a great view of the trans and the road underneath. The noise is loud and coming from the trans/clutch area...
I'm well prepared (mentally and tool-wise) to tackle the job of removing the trans and clutch.
Can somebody give an overview of what to expect?
Is it a loooonnnng and dificult job?
Or one of those ''jee, there was nothin' to it'' affair?
Any input, stories, advice and insight appreciated,
whizzerick
do you have the enclosed drive train in your 53-1300?? Fred
Redryder pix
My Hotrod
You have to disconnect the drive shaft from the back of the transmission anyway. Do that, then try starting the engine.
Your noise may or may not be in the torque tube. That little test will help you pinpoint the wik-wik-wik..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
I vote for speedo cable.
54 3100 with 235
62 flatbed dump C60 with 261
Tony M, I disconnected the speedo cable.
The noise now has modulated from a 'wik-wik-wik' to a loud and constant 'schhhwwik-schhhwwik-schhhwwik-schhhwwik'.
It is annoying and very uncool.
rick
53 4 me, this wont do: the noise stops when at a standstill. It's definitely a ''when the drivetrain is engaged'' kinda noise.
The clutch is working fine, the pedal is good.
Torque tube? We'll see.
rick
Whizzer: we have to hear a tape of that noise, I'm getting confused!!! popcorn The Truth is Out There (Do you feel like Fred Flintstone with the floor off)
Did you disconnect the cable at the transmission? I missed that you said that.
54 3100 with 235
Turn your hearing aid down and the noise will
be gone for good.
Fritz Peyerl
Fritz, I'm 36 years old...
The only thing I've lost so far is half of my hair.
That and the ability to drink large quantities of cheap lager...
rick
You might have a loose bolt in the torque tube u-joint. The bell is easy to disconnect, just remove the 4 bolts and mount and slide it aft. The transmission is easy to do if you have a cherry picker, you can take it out through the floor.
Paint & Body Shop moderator
whiz, when you take the floor cover off, you should be able to tell if it is in the shaft/tube, someone told me that the transmission was not heavy, I guess at 62 I most be weak because to me that thing is pretty heavy, I handle mine enough a while back, Fred
Redryder pix
My Hotrod
whiz, I forgot and someone may have already advised, but when you pull off the floor cover, just set the brake, put it in gear and you will know real quick if it is in this area,,mine went out last yr, luke and others gave me instructions how to replace, mine u joints broke without any prior warning. I replaced mine without to much trouble other then doing it by myself and having to get under the truck many time to adjust the jack, at any rate, mine came out again after 8 miles, don't know why, I replaced mine with the blazer/s10 set up. a mech told me he thought that I may not have tighten the u bolts tight enough, I think they only require 7 lbs, did not have torque wrench, but I felt that I did have at least that much, that isn't much at all and I did not want to strip them out, anyway good luck, hang tough, as you know others will help, you see, I don't joke all of the time,,,,Fred
Redryder pix
My Hotrod
Anonymous
Unregistered
Anonymous
Unregistered
I think it is the U-Joint going bad. I remember that wik-wik-wik sound . . .
'Nuther thought....
Try backing up for some distance at 10 or 12 mph, and see if you hear the same sound.
Report back.
Wizz, like Fritz says, disconnect the speedo cable at the trannie. If it is still connected to the trannie the cable is still turning. It is just not turning, or in this case, trying to turn the head. Disconnest it at the trannie before you rule it out. The speedo cable could be broke at any point between the trannie and the head. It sure sounds like the problem to me. Good luck. Mike cool
Since y'all can still hear, just turn your stereo up so loud you can't hear the wicky noise. Drive it till it breaks, it's easier to diagnose that way. grin
Fred
52 3600
69 C-10
Whizzerick please advise us imediately if the sound progresses to a Schwing Schwing Schwing Sound!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
