3 members (Bucker, 3B, Snowman51),
94
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31094 08/05/2003 2:09 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Hum... An annoying 'wik-wik-wik' noise is coming from the drivetrain. It has a high pitch metalic sound, like a worn bearing, in the clutch area. It does NOT stop when I depress the clutch, so I'm ruling out the release bearing? It is quite noisy and getting on my nerves... Any ideas what can cause this? Any input would be appreciated, thanks whizzerick | | |
#31095 08/05/2003 2:18 PM | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Good morning Rick (6 am here in Calif) Do you hear it when stopped and idling ? or only when moving ?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#31096 08/05/2003 2:55 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Morning! Only when moving. It modulates from a 'wikwikwikwikwik' to a 'wik-wik--wik---wik----wik' when slowing down... | | |
#31097 08/05/2003 3:37 PM | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | I don't think it is "wik-wik-wik." Yer truck is saying "quick-quick-quick fix me!" (Laughing).
Without some more information it is hard to diagnose noises, he** I can't even diagnose my own.
Could be:
1. One thing scraping on another, like a brake shoe, tire contacting something, spring in the seat bouncin' up an' down.
2. Bearing noise can be almost anywhere--front, back, drivetrain, etc.
If you hear it at slower speeds (10 to 15 mph) maybe have somebody ride in the back (or let 'em drive, if you're not afraid). Try to pinpoint the location.
If you have GOOD, DEPENDABLE jack stands, maybe try raising the rear wheels. Unfortunately, some noises go away when there is no load. Just don't crawl under the truck up on jack stands when it is running--ever!
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
#31098 08/05/2003 4:45 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Whizzer: Good to see ya: Sounds like your clutch plates are getting worn. Does it shift alright or grind when shifting, clutch pressure on pedal Ok or does it feel weak, I agree with Glenn put it on stands let it idle and put it in gear. Isolating is your biggest problem. popcorn
The Truth is Out There (I have to smile every time I see a motorized bicycle) Ben | | |
#31099 08/05/2003 8:45 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Yes, the clutch is likely the culprit. I have access to an alignment lift (a very safe lift for that kind of diagnosis), I'll keep you posted on my findings. Thanks! rick | | |
#31100 08/05/2003 10:31 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | IS this only when moving? If so, it will be something inside the tranny or at the rear of the tranny or back toward the rear end. Could be a wheel bearing/seal/dust-shield,,ANy recent work on the wheels??? Have you trued disconnecting the speedo cable from the tranny and then drive it to see if the noise goes away?
#31101 08/05/2003 10:39 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Whiz, what is a 53 1300, is that a half ton? just turn your radio up and the noise will go a way, that will be $1000 just because you are my friend,,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#31102 08/06/2003 2:31 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Mechaniac, it is only when moving. I have replaced the front-right-outer bearing and will replace the inner tonight. I am almost sure that it comes from the transmission area, though. Now may be a good time to take out the trans, replace the rear motor support, check the clutch and replace the leaky rear main seal. I wish I could have waited till winter...
Joker, now I know where you got that surname... :rolleyes: | | |
#31103 08/06/2003 2:57 PM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | dumb question and a thought
could it be the speedo cable , my made sqeeking noises and a few drops of lubricant solved the sqeek. | | |
#31104 08/06/2003 3:00 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I vote for pilot bearing.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#31105 08/06/2003 3:18 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Fritz, that's interesting as my speedo stopped working a while back. I'd have to check that out BEFORE attacking the trans. Thanks for the 'heads up'. rick | | |
#31106 08/06/2003 3:45 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Mechainiac Shop Shark Stovebolter # 930
posted 08-05-2003 05:31 PM -------------------------------------------------------------------------------- IS this only when moving? If so, it will be something inside the tranny or at the rear of the tranny or back toward the rear end. Could be a wheel bearing/seal/dust-shield,,ANy recent work on the wheels??? Have you trued disconnecting the speedo cable from the tranny and then drive it to see if the noise goes away? -------------------- "Always use the word "Impossible" with the greatest caution"
#31107 08/06/2003 3:46 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Might look up a few posts LOL
#31108 08/06/2003 3:57 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Woa! I missed that one Mechainiac! Thanks! I guess I was blinded by the idea of having to remove the trans ans clutch... I'll keep you posted. rick | | |
#31109 08/06/2003 4:36 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | No problem, Fritz had you covered I highly suspect the speedo cable since you stated that it quit working awhile back - Disconnect the fitting at the tranny(rear)and see if the noise goes away(eliminate the simple things first)
#31110 08/06/2003 6:15 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Well. I just got back from lunch and before leaving I took the large 'floor section' out, leaving a great view of the trans and the road underneath. The noise is loud and coming from the trans/clutch area... I'm well prepared (mentally and tool-wise) to tackle the job of removing the trans and clutch. Can somebody give an overview of what to expect? Is it a loooonnnng and dificult job? Or one of those ''jee, there was nothin' to it'' affair?
Any input, stories, advice and insight appreciated, whizzerick | | |
#31111 08/06/2003 7:04 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | do you have the enclosed drive train in your 53-1300?? Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#31112 08/06/2003 7:20 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | You have to disconnect the drive shaft from the back of the transmission anyway. Do that, then try starting the engine.
Your noise may or may not be in the torque tube. That little test will help you pinpoint the wik-wik-wik..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#31113 08/06/2003 7:22 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 |
54 3100 with 235 62 flatbed dump C60 with 261
#31114 08/06/2003 7:31 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Tony M, I disconnected the speedo cable. The noise now has modulated from a 'wik-wik-wik' to a loud and constant 'schhhwwik-schhhwwik-schhhwwik-schhhwwik'. It is annoying and very uncool. rick | | |
#31115 08/06/2003 7:38 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | 53 4 me, this wont do: the noise stops when at a standstill. It's definitely a ''when the drivetrain is engaged'' kinda noise. The clutch is working fine, the pedal is good. Torque tube? We'll see. rick | | |
#31116 08/06/2003 7:56 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Whizzer: we have to hear a tape of that noise, I'm getting confused!!! popcorn The Truth is Out There (Do you feel like Fred Flintstone with the floor off) | | |
#31117 08/06/2003 8:04 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Did you disconnect the cable at the transmission? I missed that you said that.
#31118 08/06/2003 9:51 PM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | Turn your hearing aid down and the noise will be gone for good. | | |
#31119 08/07/2003 12:06 AM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Fritz, I'm 36 years old... The only thing I've lost so far is half of my hair. That and the ability to drink large quantities of cheap lager... rick | | |
#31120 08/07/2003 12:25 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You might have a loose bolt in the torque tube u-joint. The bell is easy to disconnect, just remove the 4 bolts and mount and slide it aft. The transmission is easy to do if you have a cherry picker, you can take it out through the floor.
#31121 08/07/2003 1:25 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | whiz, when you take the floor cover off, you should be able to tell if it is in the shaft/tube, someone told me that the transmission was not heavy, I guess at 62 I most be weak because to me that thing is pretty heavy, I handle mine enough a while back, Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#31122 08/07/2003 1:39 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | whiz, I forgot and someone may have already advised, but when you pull off the floor cover, just set the brake, put it in gear and you will know real quick if it is in this area,,mine went out last yr, luke and others gave me instructions how to replace, mine u joints broke without any prior warning. I replaced mine without to much trouble other then doing it by myself and having to get under the truck many time to adjust the jack, at any rate, mine came out again after 8 miles, don't know why, I replaced mine with the blazer/s10 set up. a mech told me he thought that I may not have tighten the u bolts tight enough, I think they only require 7 lbs, did not have torque wrench, but I felt that I did have at least that much, that isn't much at all and I did not want to strip them out, anyway good luck, hang tough, as you know others will help, you see, I don't joke all of the time,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#31123 08/07/2003 6:04 AM | | Anonymous Unregistered | | Anonymous Unregistered | I think it is the U-Joint going bad. I remember that wik-wik-wik sound . . . | | |
#31124 08/07/2003 4:45 PM | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | 'Nuther thought....
Try backing up for some distance at 10 or 12 mph, and see if you hear the same sound.
Report back.
#31125 08/07/2003 5:07 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Wizz, like Fritz says, disconnect the speedo cable at the trannie. If it is still connected to the trannie the cable is still turning. It is just not turning, or in this case, trying to turn the head. Disconnest it at the trannie before you rule it out. The speedo cable could be broke at any point between the trannie and the head. It sure sounds like the problem to me. Good luck. Mike  | | |
#31126 08/07/2003 6:58 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Since y'all can still hear, just turn your stereo up so loud you can't hear the wicky noise. Drive it till it breaks, it's easier to diagnose that way.
Fred 52 3600 69 C-10
#31127 08/07/2003 7:18 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Whizzerick please advise us imediately if the sound progresses to a Schwing Schwing Schwing Sound!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
