1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
50 3100 with 3-sp on the column. It gets stuck in 2nd or 3rd periodically. I can get it home but it's not good for the clutch. I loosen the bolts on the linkage rods, screw around with everything and get it to work great again--for awhile. (I really don't know what particular thing I do to fix it) What's more likely? Do I need a new shift box or do I need to tear into the transmission?
Hi, had the same problem for a while and could not figure it out, kept on adjusting the linkage, finally checked the connection down under on the transmission and found out the connection bolt on the shifter arm bracket had loosened up. Fixed my problem. Dutch
Check the shifter box on the collumn mine is worn out and the shifter slides between the 1/r and 2/3 forks causing jamming. The shop manuel should give a gap spec for the forks & thickness on shifter lever. worth checking.
Brad smile
