| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30988 03/25/2004 3:33 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I adjusted my Huck brakes since only one shoe was well-adjusted on each wheel. The brake pedal went down half-way but it was still driveable and I drove it to work. The truck sat all day.
At the end of the day, I hit the brake pedal and it wouldn't go down much at all. I hadn't used the parking brake (granny gear instead) and I didn't pump the pedal. Something had changed.
All four wheels are tight so it wasn't just one hinky wheel. It must be the MC. I retracted the MC plunger by about 1/16" and the brake pedal now goes most of the way to the floor.
Anyone know what might have happened? This is a new dual reservoir MC, lines and rebuilt wheel cylinders but it hasn't been driven for many months. How can a brake system almost lock up while just standing??
Thanks! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30989 03/25/2004 3:54 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | When you said "all the wheels were locked" I thought of the master cylinder pluger covering the return port so the fluid couldn't return to the reservoir.....that's why all the brakes were locked.
The only reason I can think of for them to get tight would be possibly moisture in the brake fluid??
Joe
#30990 03/25/2004 4:24 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | I had a similar problem with my 51 1-ton with huck brakes, although only my rears locked up. It turned out that both of my rear brake return springs were broken or missing. The springs on my 1 ton were 3-piece, being the spring itself, and the spring hooks that slid in and out of the tightly coiled spring ends. Anyway I only needed two,but Napa ordered eight just to stock up. About half were delivered with the spring hooks having already fallen out of the tightly coiled spring ends.
Bottom line is, if you have the 3 piece spring it might have failed even if brand new. | | |
#30991 03/25/2004 5:06 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :rolleyes: chevy 1 - That exact thing happened to me. The plunger in the MC wouldn't move far enough back to unplug the drain back hole. My brakes were slightly engaged all the time. I almost never figured it out and finally removed the cover on the MC, looked in and saw the problem. Turned out the MC had been assembled incorrectly. It worked great after it was reassembeled correctly. Wally / Montana, you might check to be sure the MC is correctly assembled, especially if you didn't assemble it.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#30992 03/25/2004 5:38 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Thanks for the help. It looks like I need to readjust the MC plunger outward and then readjust the brakes. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30993 03/28/2004 4:59 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Wally, Could you describe the system you just put in? What kind, bore, of mc, did you add residual pressure checks, are you using a proportioning valve? Did you replace the brake hoses? I'm very interested now that I've just acquired a '50 gmc 3/4 ton.  | | |
#30994 03/28/2004 5:02 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I've had Hucks lock up while sitting, and usually the problem has been failed return springs in the rear axle. | | |
#30995 03/30/2004 5:15 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Splashoil,
I used the adapter kit from Classic Performance but ordered the MC from NAPA by number. I'll get the info to you when I return from the coast to Montana. There's no proportioning valve.
It has all new lines and hoses. I rebuilt the rear wheel cylinders but the front had seen a recent rebuild.
I'm pretty sure this was a hydraulic problem and not a mechanical spring problem. All 4 brakes had become tight and the brake pedal became fully extended at the same time. When I adjusted the MC plunger outward about 1/16", all 4 wheels loosened up and the brake pedal went down nearly to the floor. I believe the plunger was not coming out far enough to expose the relief valve. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
