| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I am re-plumbing my engine and would like to know where you guys locaate your fuel filter? I am thinking of a direct line from the fuel pump to the carb. The po had a filter in this line and it was located just in front of the carb but over the mainfold. Thanks Oh, it is a GMC 228 | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I have an in-line filter between the tank and the fuel pump along with a smaller one which screws directly into the carb. I like that combination. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I have an original accessory AC glass bowl filter located in the line right before the carb, where the accessory insallation manual shows. I don't see any problems with it being above the manifold. I have been thinking about adding one in line between the tank and pump, but haven't done it as of yet.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Fuel pumps push better then they pull. So you get better fuel flow with the filter between the pump and the carb (the original design).
However, if you have a fuel tank with sediment, you really need one before the fuel pump. I used filters in both places when I was running with a cruddy tank. When I finally got a good tank installed, I put in a stock glass filter (with replaceable element) just in front of the carb. | | |
