3 members (Hotrod Lincoln, 2-Ton, 1 invisible), 63 guests, and 4 robots.
Topics128,021
Posts1,055,353
Members48,420
#3063 03/02/2005 3:13 PM
I am re-plumbing my engine and would like to know where you guys locaate your fuel filter? I am thinking of a direct line from the fuel pump to the carb. The po had a filter in this line and it was located just in front of the carb but over the mainfold.
Thanks Oh, it is a GMC 228
#3064 03/02/2005 4:03 PM
I have an in-line filter between the tank and the fuel pump along with a smaller one which screws directly into the carb. I like that combination.
#3065 03/02/2005 7:59 PM
8
8 Offline
I have an original accessory AC glass bowl filter located in the line right before the carb, where the accessory insallation manual shows. I don't see any problems with it being above the manifold. I have been thinking about adding one in line between the tank and pump, but haven't done it as of yet.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#3066 03/03/2005 2:54 AM
Fuel pumps push better then they pull. So you get better fuel flow with the filter between the pump and the carb (the original design).
However, if you have a fuel tank with sediment, you really need one before the fuel pump. I used filters in both places when I was running with a cruddy tank. When I finally got a good tank installed, I put in a stock glass filter (with replaceable element) just in front of the carb.
