9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#30615 08/13/2004 6:29 AM
Could someone tell me the difference in a manual or electric choke. Obviously the electric has something to do with 12 volts but I'm just not quite sure how. I am putting it on a 350 so any tips would be greatly appreciated
#30616 08/13/2004 6:44 AM
I have an Edelbrock 1406 4bbl carb with an electric choke on my 350.
There's a wire that goes to the choke ... comes from any key-on power source.
The difference:
Manual choke must be operated by hand; a cable runs from the choke to your dash and you pull on the cable to add more choke; push it in when you don't need choke.
Electric choke operates automatically; no need to deal with it yourself.
TO ADJUST AN ELECTRIC CHOKE (Edelbrock):
1 - Warm up your engine to operating temp and remove the air cleaner so you can see the choke flap.
2 - Loosen the screws on the plastic choke cover and turn the cover clockwise (right) until the choke flap just BEGINS to close.
3 - Turn the choke cover COUNTER-clockwise (left) ONE notch and tighten the screws down.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#30617 08/15/2004 6:10 AM
thanks for the help thats what I needed to hear
