2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#30595 02/14/2003 9:29 AM
For thos who are interested-
Normal vacuum: All motors regardless of number of cylinders all have about the same vacuum. 15 to 20 inches of mercury (in-Hg) At wide open throttle (WOT) it will approach 0. On deceleration it can briefly go as high as 25 to 28 in-Hg. I think higher compression motors are at the high end while our big lumbering 360;s are middle to low end with 454's being the lowest. Don't quote me on that. For every 1000 feet above sea level, normal readings will drop 1 in-Hg
Cranking vacuum: 1-4 in-hg when cranking with the ignition disabled and throttle at WOT.
Operating vacuum: 15-20 in-Hg at idle. 19-21 in-Hg at steady 2500 rpm. About 0 at WOT. 25-28 while decelerating. In all cases the needle should be fairly steady.
Low stead reading: Leaking gasket carb base, leaky vacuum hose (biggest FSJ problem), late ignition timing or late crankshaft timing (jumped timing chain?)
Low fluctuating needle: Needle fluctuates three to eight inches below normal. Suspect a leak in the intake manifold gasket.
Regular drops: Two to four inch consistent drop. Likely a leaking valve. Perform a leakdown and compression check to isolate the bad valve.
Irregular drops: Two to four inch occasional drop. Sticking valve or ignition misfire. Do a leakdown and compression check as well as inspecting the plugs for fouling.
Rapid vibration: A rapid 4 in variation at idle combined with exhaust smoke indicate worn valve guide. Perform leakdown test to confirm. If rapid vibration occurs with an increase in engine speed, check for a leaking intake manifold gasket or head gasket, weak valve springs burned valve or ignition misfire.
Slight fluctuation: A slight 1 inch fluctuation may mean ignition problems Check all tune up items and try an ignition analyzer.
Large fluctuation: Perform compression or leakdown test to find a weak or dead cylinder or blown head gasket.
Slow Hunting: Needle moves slowly through a wide range. Check for clogged PCV, incorrect idle mixture or carb to manifold gasket leaks.
Slow return after revving: Snap throttle to WOT until engine at 2500 rpm. then release. Vacuum should drop to 0 then go to 25-28 then back down to normal. If vacuum returns slowly and doesn't peak the rings may be worn. If there is a long delay, look for a restricted exhaust. If the exhaust seems restricted, disconnect at manifold and repeat the now loud test. grin
#30596 02/14/2003 1:46 PM
Great info, thanks for posting! One question, where is the best place to connect the vacuum gauge when checking a 235? I have been told to connect it to the carb and the manifold, which is best. Thanks.
Steve
55 1st Series 3/4 ton
#30597 02/14/2003 10:39 PM
The manifold is usually the easiest and gives the best signal.
Paint & Body Shop moderator
#30598 02/15/2003 8:13 AM
What 4otf said smile
#30599 02/15/2003 8:47 PM
I disconnect my vacumn wiper hose from the intake and connect the gauge there. At idle, mine ran a smooth 22#. Needle barely flickers....
Craig
