1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#3057 07/16/2004 5:53 PM
Apprentice
Apprentice
Does anybody have any sugestions for a disc brake conversion? I have a 1951 1/2 ton, that is going to be a daily driver. I want keep the straight axle and switch to disc brakes and 4 3/4 bolt pattern.
If you've done this, please let me know your thoughts...
I am not opposed to the idea of converting all four wheels, MC, bearings, and all the brake lines. Most importantly, is there any Vendors I should stay away from?
Thanks in advance!
fifty-one half-ton
#3058 07/16/2004 9:21 PM
Burrell,
Check these guys out.
I am planning on getting some of their kits.
Never used them, but they seemed to be engineered well enough...
http://www.classicperform.com/product-pages/trucks/five-lug-disc-brake-kit.htm
#3059 07/16/2004 11:03 PM
Apprentice
Apprentice
Thats the one I'm thinking about getting. Are you going to do all four wheels or just the front?
fifty-one half-ton
#3060 07/16/2004 11:39 PM
Anonymous
Unregistered
Anonymous
Unregistered
Burrel, Cletis in Parker County, Teaxs is installing a disk set now and has a web site showing what he is doing(http://jbhardin-gallery.com/trucks/54gmc.html)
tony'n weatherford grin
#3061 07/17/2004 6:20 AM
Burrell,
Recommend Engineered Components, Inc.
Have done 2 conversions using their kits and components and it is good stuff!
Call them, there is more to converting than just a kit. They will help you get ALL the needed stuff you need from the pedal to the pads and have answers for all your questions.
All they do is brakes!
Web site: http://www.ecihotrodbrakes.com/catalog.html
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
#3062 07/18/2004 2:51 AM
I used the kit from Chevy Duty to do my fronts. At the same time I converted to a dual master and reran all the lines.
I already had the rear axle from a '73 Chevelle wagon under the rear, and since the Chevy Duty kit is based on mid-70's mid-size GM I was able to buy '73 Chevelle master cylinder, rotors and calipers to use with the porportioning valve I'd kept from the wagon.
I'm happy with my conversion and have been driving it almost daily for more than 18 months.
