4 members (Hotrod Lincoln, Southerntruck, Rich'sToys, 1 invisible), 83 guests, and 3 robots.
Topics128,090
Posts1,056,373
Members48,442
#30559 03/11/2005 11:31 PM
whats it do if mine is froze open and the spring is gone can i leave it that way when you run duals you dont have one dose it give it back pressure or whats it for
#30560 03/12/2005 12:30 AM
Riding in the Passing Lane
If its in the open possition like you say & you are not in a real cold climate you can leave it alone. If you want to free it up spray it with penatrating oil & tap it back & forth with a hammer. smile
1972 Chevy c10 Cheyenne Super
#30561 03/12/2005 5:23 AM
H Online: Content
It's called a "heat riser", and it's intended to warm up the intake by routing exhaust gas under the intake during cold starting. If it wasn't necessary, why did GM go to the trouble and expense to install it? I'd suggest getting it working freely, and replacing the spring in the process if you can find one. The spring is supposed to hold the valve closed when the engine is cold, and the weight opens the valve as the manifold heats up.
#30562 03/12/2005 6:30 AM
Whatever you do, don't grab the shaft with visegrips and twist it. Best way I have found to free it up is to remove the manifold. Start with PBblaster or Kroil and a small hammer. A torch helps, heat the manifold, not the shaft. Sometimes I've only been able to get the shaft to move in and out, but not rotate, which requires drilling out the rivets that hold the flapper. Also, a lot of times someone has tried turning the counterweight with pliers, and has sheared off the pin through it.
Fred
52 3600
69 C-10
