0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30412 03/11/2004 8:41 PM | Joined: Mar 2002 Posts: 31 Junior Member | | Junior Member Joined: Mar 2002 Posts: 31 | I have just reinstalled a Carter BBD-4925 two bbl on my Chrysler. Engine was timed and running smoothly before rebuilding the carb. Now I am at the on-engine fine tuning phase of the rebuild. The carb won't curb idle - it putters to a stop. Starts right up, but can't take m' foot off the gas pedal to idle.
Anyway, I was punching the pedal to check that the acceleration jets and the pump were working ok and got a couple of thru-carb backfires, spitting flame up about 4-6 inches.
Any ideas what causes this? I'm prepping to get back under the hood this Saturday.
Cheers from NC
Spito, spitero, huchtooey splateus! 1958 GMC Series 100 stepside 1954 Chevrolet Bel Air 4-DR sedan 1966 Chrysler Newport 2-DR hardtop
#30413 03/11/2004 9:28 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Flame coming out of the carburetor indicates a cylinder is firing while the intake valve is open. Possible causes are many (stuck or burned intake valve; valve timing; timing chain skipped tooth; spark plug wires on on correct wires; defective vacuum advance; cracked or carbon track in distributor cap; defective carbon spark plug wires; more).
Would suggest starting with a compression test, which will tell you the condition of the valves.
It doesn't take many backfires to melt the venturi cluster in the carburetor.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#30414 03/11/2004 9:28 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | If it runs with the foot on the pedal, I'd say it sounds like it's too far advanced. Maybe a bit too rich too. Back off the timing, lean it out, get it running and tuned up, then adjust the timing again.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#30415 03/12/2004 4:09 AM | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | its lean and most likly retarded due to a worn out chain the fire up the carb is a slow acelerator pump causing a lean mixture I know this because it took me 3 weeks to fix mt dodge van once | | |
#30416 03/12/2004 5:54 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | if it won't idle, I'd say the culprit is a vacuum leak. This could also lead to a lean backfire.
I'd start searchin for loose, cracked or broken vacuum lines. If that doesn't fix it, then start sprayin carb cleaner around the carb, especially the vacuum lines and the base of the carb where it fastens to the manifold. If the engine speed increases when ya spray the stuff in that area, you've probably located the source of the vacuum leak.
Now my 64 C10 spits thru the carb....bit since it doesn't have a choke and it's a little cold blooded, I figger that it's just a lean backfire and I don't worry about it, cuz it goes away when it warms up. And it's gettin an electric choke AFB carb here pretty soon anyway. Like I might start workin on it tomorrow, if the good Lord's willin and the creek don't rise. Hmmm...I might actually have a hopped up 292 by the end of the weekend. How bout dat? | | |
#30417 03/16/2004 6:16 PM | Joined: Mar 2002 Posts: 31 Junior Member | | Junior Member Joined: Mar 2002 Posts: 31 | Thank you all for the input.
Yeah, this is a tough carburetor to tune, I'll say! There are two mixer nozzles in the front base of the carb and a third in the back that seems to be for curb idle mixture (that's three mixtures).
I may have the thermostatic coil too lean, but I think I have the three nozzles too rich.
I finally found a MOPAR Master Technicians' Service Conference bulletin for 1968 Carter BBDs and will have to read that. I do know now my carb is a 68 on a 66 car.
#30418 03/17/2004 7:57 AM | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Mybe you should just get rid of the chrysler and drive one of your real vehicles  | | |
