7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30358 07/27/2004 8:21 PM | Joined: Apr 2002 Posts: 7 Junior Member | | Junior Member Joined: Apr 2002 Posts: 7 | i was wondering what other engines have the same engine mount paterns, and bell housing patterns as a 248/288/316? i recently purchesed a 1955 GMC 2nd series 3/4 ton truck. it was an original v-8 but now has a correct year 248 inliner. i am interested in putting a newer olds/pont (57- 65) in it.
thanks | | |
#30359 08/09/2004 9:06 PM | Joined: Jul 2004 Posts: 1 Junior Member | | Junior Member Joined: Jul 2004 Posts: 1 | I'm in the middle of doing the same thing to my 56 GMC 2 ton. From the looks of it a 400/455 should mate up, if you use the original bellhousing. You may need to grind a little on the front mount, due to balancer clearance.
Brian | | |
