0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
If I replace my 216 with a 235 is there any standard exhaust systems I can buy - or will it have to be custom made. (Since exhaust manifold on 235 is angled back, rather than straight down on the 216?)
My "custom-made" system only cost $125 (but it didn't come with a lifetime warranty). Have you been given an estimate?
No, I have not had an estimate. I was wondering if I could buy the exhaust system from one of the chevy parts stores. Since this seems like a common swap, I was wondering if I would have to take it to a muffler shop. I have a 235 in the PU now but it has 216 manifolds and a Carter W-1 carb. I would like to find some 235 manifolds (54 or latter) and a corresponding carb and hopefully improve its performance.
I have a 37 Chevy pickup w/56 235 motor with the 235 exhaust manifold. I am in the process of getting an exhaust sytem. I have been told there area several options; 1) use a 235 down pipe hooked up to a 37 muffler & tail pipe, 2) use the 216 down pipe & have it bent to the angle of the 235 exhaust manifold, 3) have a custom exhaust system made. I'm just at this point and weighing my options & costs. Hope this helps.
1937 Chevy pickup
1952 MGTD
What problem are you experiencing I have a 57 235 in my 50 Chev 1/2 ton column shift and just had to shave a bit of the geer linkage off to make it pass the manifold....works fine...put in exhaust a a plain old exhaust shop for $125.
