| | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30316 05/28/2003 9:04 PM | Joined: May 2001 Posts: 3 Member | | Member Joined: May 2001 Posts: 3 | If I replace my 216 with a 235 is there any standard exhaust systems I can buy - or will it have to be custom made. (Since exhaust manifold on 235 is angled back, rather than straight down on the 216?) | | |
#30317 05/28/2003 10:51 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My "custom-made" system only cost $125 (but it didn't come with a lifetime warranty). Have you been given an estimate? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#30318 05/29/2003 3:08 AM | Joined: May 2001 Posts: 3 Member | | Member Joined: May 2001 Posts: 3 | No, I have not had an estimate. I was wondering if I could buy the exhaust system from one of the chevy parts stores. Since this seems like a common swap, I was wondering if I would have to take it to a muffler shop. I have a 235 in the PU now but it has 216 manifolds and a Carter W-1 carb. I would like to find some 235 manifolds (54 or latter) and a corresponding carb and hopefully improve its performance. | | |
#30319 05/29/2003 3:58 PM | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I have a 37 Chevy pickup w/56 235 motor with the 235 exhaust manifold. I am in the process of getting an exhaust sytem. I have been told there area several options; 1) use a 235 down pipe hooked up to a 37 muffler & tail pipe, 2) use the 216 down pipe & have it bent to the angle of the 235 exhaust manifold, 3) have a custom exhaust system made. I'm just at this point and weighing my options & costs. Hope this helps. | | |
#30320 05/29/2003 4:44 PM | Joined: Jun 2001 Posts: 27 Member | | Member Joined: Jun 2001 Posts: 27 | What problem are you experiencing I have a 57 235 in my 50 Chev 1/2 ton column shift and just had to shave a bit of the geer linkage off to make it pass the manifold....works fine...put in exhaust a a plain old exhaust shop for $125. | | |
