5 members (rick46ia, elhippie64, Peggy M, JW51, 1955firstseries), 66 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#30283 10/11/2003 5:56 AM
I'm hanging a resored door on my 51.the bottom hing needs to be bent a little to make it fit the body.I had a 54 I restored and remember in the manual I had it explained the bend the hing to fit the cab better. Problem is I have the factory assembly for 47 to 54, the shop manual for 51 and 54 and can't find the info. All they show is up,down foward aft. No in out. I had the 54 in the 70s. I would love to know now what I knew then. If any one can help I will name the spud truck after them. Thank you O. :confused:
#30284 10/11/2003 11:26 AM
door alignment is voodoo science...
54 3100 with 235
62 flatbed dump C60 with 261
#30285 10/11/2003 11:35 AM
Tony M is right - I never found any info on how to do it. Here is what I discoverd through trial and error.
http://www.chuckthetruck.homestead.com/page20.html
http://www.chuckthetruck.homestead.com/page21.html
http://www.chuckthetruck.homestead.com/page22.html
I haven't taken a pic yet of the latest, but they are almost perfect now - bottom of the drivers door is out 1/16" everywhere else is flush.
#30286 10/13/2003 9:10 AM
O.K. Its Chuck 2 or II or two or as well or in addition to or icluded as. Thankyou very much,I happened to have an extra 8 and a half hours to put the door on, remove it and repeat. Many times, or should that be many many? I got the door to fit to a T now I can put a new corner on the thing. Still waiting for the lower left rear door piller to show to start the driver side. A thousand thanks to you the Chuck.O cool
