| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | Sorry if this has been answered before, but I have a 1950 GMC 1/2 ton. I think they have 15" 6 lug, with 5 1/2" spacing? I'm looking at a good deal on wheels and rims (badly needed). Problem: The wheels are 16", P235/75R16. Will these work?
'50, '59, 1/2T, GMC
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Welcome to The 'Bolt, tater (cute name!  ). Others will chime in with more specifics, but yes, that wheel and tire combo should work A O.K. on your rig. 16" wheels were original on these rigs up until '54, I believe, when 15" wheels became optional. Most important thing will be to be careful with the wheel backspacing, you might run into interferance with your tie rod ends. If you can try one of the new wheels on for size on the front (before you buy), this will let you know right away if they will fit. Hope this helps. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | Thanks Wannabe. Found out the wheels have 5" back spacing.
'50, '59, 1/2T, GMC
| | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello tater. the tire size you asked about [235/75/16] is the same size as the new size on my 99 silverado. it rang a bell because in 99 i could not find snow tires as the size was so new. even goodyear did not have a snow tire the same size at that time. i was always curious to see if the silverado wheels would work on my 55 first series. so i guess i would ask if those wheels are similar to what you are looking to buy? if so i will be willing to try them on my truck before you buy them, that is i will take the spare from the silverado and try it on the ad truck. let us know if we are on the right track. good luck.
our garage is a non-profit organization
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Tater, I think you'll find that you need 3.75" or less for backspacing or you'll hit the steering knuckle. Your search will be easier than mine, as I have 8-lug wheels that needed to fit over tonner drums. | | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | thanks for the replys. garyg, you are on the right track, these wheels came off a new GMC Safari. They are on Ebay at very nice price. I would appreciate it if you could try your spare on the front of your truck. Thanks everyone
'50, '59, 1/2T, GMC
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | tater, the wheels on the GMC Safari will be 5-lug wheels
| | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | They're advertized as 6 lug 5 1/2 " spacing. They come from a place that does custom vans and these were take-offs. The picture shows 6 lug. The guy mentioned they may be off a G-Van.
'50, '59, 1/2T, GMC
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | tater, For what it's worth, I'm running 7.50-16, 6 luger on my '50 chevy.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | I just talked to a guy at the Truck and RV store he says these new wheels won't fit over old hubs. I guess my question is to garyg. Did you get a chance to try your wheel on the '55?
'50, '59, 1/2T, GMC
#3033 05/20/2003 12:34 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello tater. just came in. the newer wheels fit over the hub, and clear everthing but the tie rod end and steering arm. when i got a good look at the back spacing on them, i didn't think they would even bolt up , but they went on further than i thought they would. it is to bad because they look pretty good on there. i didn't try them on the back. good luck.
| | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | thanks for trying, I think I'll have to give up on that idea
'50, '59, 1/2T, GMC
