2 members (baldeagle, elhippie64), 63 guests, and 11 robots.
Topics128,020
Posts1,055,345
Members48,420
#30172 05/18/2002 6:19 AM
From time to time I see posts where people are asking "What is the right size carb to run". I ran across the following two sites and thought they might be helpful.
http://users.erols.com/srweiss/calccarb.htm
http://www.taperformance.com/cfm.htm
Rick :rolleyes:
#30173 05/19/2002 6:59 AM
Note that those are both for 4 bbl carbs, 2 bbl carbs use a different flow measurement system. I just wish that I knew the relationship between the two.
Fred
52 3600
69 C-10
#30174 05/19/2002 11:25 AM
Ok Fred, we all know relationships are difficult but......4 bbl carbs are rated for cfm at 1.5 Hg of pressure drop(vacuum)and 2 bbls are rated 3 Hg of pressure drop.To rate a 2 barrel the same as a 4 barrel a conversion factor of 1.414 can be used. So, for example,a Holley 500 cfm 2 bbl carb is 353 cfm if rated on a 4 bbl scale.The above information is from various carb tuning books.
#30175 05/19/2002 3:38 PM
Well, as for thr one-barrel carbs, CFM =Can`t Flow Much! grin
#30176 05/19/2002 5:53 PM
What is the max RPM of a 1958 series 235?
What is the volumetric efficiency of a 1958 series 235?
What is the importance of volumetric efficiency?
#30177 05/20/2002 9:44 PM
JD, your max rpm depends on how long you want the engine to last and what you have done to improve it. Continuous running of a stock 235 over 3,000 rpm is not recommended. I've had mine (with a 3/4 race cam) up to about 4,500, but only for a very brief period. If you have balanced rods & crank, electronic ignition, the right pistons and valve springs and a better damper, 6,000 is obtainable, but not recommended.
Fred
52 3600
69 C-10
