| | | Forums66 Topics128,049 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Like Joy said in her post in the Lounge, I'm just installed a new water pump on our 45 2 ton Chevy. This truck has a later 235 using an adapter allowing use of the original style 216 pump.The adapter has been in use for 2 years.The adapter is nice, retains the original wide fan belt pump for use with 6 volt generator, and keeps the fan in the stock higher location for better cooling.The Damper Doctor rebuilt a 235 damper fitted with the smaller wide pulley from a 216. The new not rebuilt pump was ordered from Chevy Duty, excellent service. The pump is made in Mexico, looks nice, but has a machined cast iron pulley instead of the stamped metal pulley like the original pump.Before installing the pump in cramped quarters,I checked the fan fit.All bolt holes lined up, good. I bolted on the pump and adapter quickly, went to install the 216 style fan...oh no, the fan rivits foul on the pulley.Wildlife scatters , frightened by my swearing,#$@&^%$. Then out comes the grinder to notch the pulley slightly for the fan rivit heads. If you buy on of these pumps, bolt up the fan to the pulley beforehand and check to see it draws up flush against the pulley flange, its way easier grind the pulley on your workbench.The original pump will be sent to Arthur Gould's in NY for rebuilding. | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | I bought a pump from Carter's for my '54 engine. I'm not thrilled with the cast pulley, mine broke at very low mileage. It had low mileage but was almost two years old because of the time it took to do my restoration. Carter's people responded that how do they know it had low mileage and I must have overtightened the belt. This is not the first vehicle I have owned or put a belt on, never saw this happen before. I found that local parts place carry's the same pump and also has a warranty, but rebuilding sounds like a better choice with the steel pulley.
BTW Tony, thanks for the info on the adapter, got your letter yesterday.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
| | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | TONY Not realy on subject, BUT I sure would like to know more about that waterpump adaptor? I looked in archives but nothing. Could i get drawing/ pic.I have more wide belt water pumps than any thing else.  | | | | | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | I also have the adapter. It is the way to go I bought my water pump from Checkers auto parts It is rebuilt but a lifetime guarantee. This adapter raises the pump about 3 inches. Only caution do not use the 55-62 harmonic balancer it turns the stock pump too fast. Mike | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | MIKE BUT where does adaptor come from | | |
#3020 09/07/2002 11:27 PM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | O.K. I am not profiting from the sale
David Folsom 22919 E. Echo Lk. Rd. Snohomish, Washington 98296 (425) 485-0173 Hopes this helps.I am not selling Mike | | |
#3021 09/08/2002 12:28 AM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 |
Buzz'n Half Dozen
#3022 09/08/2002 12:56 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | I had an e-mail address for the adapter but didn't get a reply. With the engine and tranny rebuild I'm doing I would gladly buy one, don't have time to re-invent the wheel. However, I do this kind of work for a living- experimental and development jet engine work- I can make any kind of adapter or bracket if I have to. If anyone contacts Dave please drop me an e-mail.
