9 members (Wally / Montana, UtahYork, Frank50, BarryP, BC59, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible), 125 guests, and 2 robots.
Topics128,134
Posts1,056,740
Members48,454
Does this motor look stock?? [img]http://mediaservice.photoisland.com/auction/Jul/20027161767203191961711.jpg[/img]
[img]http://mediaservice.photoisland.com/auction/Jul/20027163535498446695402.jpg[/img] ..anything look wrong/out of place.etc??... I think it's a 228..sound/look right??? Thanks!! JoninJax
looks just like the 228 that was in my 46 GMC, Jon, 'cept for the oil filter, but that was never factory anyway. mine was on the firewall above the steering col.
joninjax,
Check then engine serial number on the pad to the left of the distributor. GMC encoded the engine size in the first few digits of the serial number. i.e. 248..., 302...
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
Thanks OlBlue... does this look all original..correct air cleaner, horn etc? Thanks!
All looks good and original.I suppose a little cleaning and paint is on the "To Do" list grin cool
The coil is even mounted upside down. It's probably never been touched since the factory!
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
Boyo, please 'splain more about the coil being upside down. Mine's in the same position, should I be rotating it and why?
Lorne
MbOutdoors (Lorne)
1952 Chev 1300
Coils were mounted upside down from the factory. I'm sure there was a good reason why, probably had to do with getting water inside. I'd keep it that way for originality sake, and for folks in the wetter states.
The only disadvantage that I know of is that coils have been known to leak, dripping all manner of gooey corrosive stuff onto a nicely painted engine.
-Boyo
