4 members (Steelonsteel, Woodcmiami, Gray_Ghost, Hotrod Lincoln), 70 guests, and 2 robots.
Topics128,050
Posts1,055,760
#30059 04/30/2002 7:23 PM
What a great forum. Let me introduce myself. My name is Jerry and my son is Lowell. We are on the verge of buying a new old GMC and this forum seems like just the ticket for neophytes like us. I use the word "old" loosely as I'm older than the truck. I'm a true novice in these matters so if somebody with some patience would be so kind as to help me through this jungle I'd surely appreciate it. My new prospective bride is a 1955 GMC 1/2 ton, LB 1st series advertised as a "GMC 100" (tho I've had a little trouble reconciling that model number with the other "facts") and I have some questions.
First BIG question: I've looked around quite a bit and can't find anything on the 270. Is there anything in particular I should know about this animal before I cage myself with it? Second BIGGER question: What other overwhelming concerns should I have relative to this year, this make, this model, etc? Third BIGGERYET question: I'm about to drive a fair piece to see (and presumably buy) it, what hugely significant things should I look for?
Last and BIGGEST question: What should I be asking and I'm not?
Any help would be oh-so-appreciated. I'm looking forward to a long and loving relationship with this forum.
Cheers, jerry
#30060 04/30/2002 9:57 PM
Jerry, welcome to Stovebolt land. You're in good company here. While a GMC is technically not a Stovebolt, it's close enough...
The 270 was GMC's base pickup engine from the late 50's thru early 60's when it was retired. Prior to that it saw extensive military use in the Korean war era. A real workhorse of a motor, Full pressure crank (no babbit dippers ever for GMC) very sturdy and reliable, some parts interchange with Chev 235 but many parts are proprietary. A little on the expensive side to rebuild. WWW.inliners.org
is a good site to learn more on the 270 Jimmy.
You should be looking for major rust damage on the '55 as this will be the most labor-intensive and expensive part of the restoration(if that's indeed what you are planning) Check the floorboards and cab corners. Otherwise just look it over like you would any vehicle and be honest with yourself about what you are getting into.
If the truck is driveable, evaluate it like you would any used car. Chevy had two totally different 1/2 tons in '55, the "1st series" and the actual 55. I think GMC did too but not sure. Look for leaking fluids, missing trim (some GMC pieces can be hard to find - unlike Chevy), operation of clutch, tranmission etc. If the motor smokes, knocks or has other bad signs, see above - GMC's are not cheap to rebuild.
I'm sure some others will add to this but be sure to visit Rob English's web site. It is the absolute best resource on the web for GMC info. go to www.oldgmctrucks.com.
#30061 05/01/2002 3:06 PM
Sixpack, thanks for the good info. Appreciate all the help I can get. jerry
#30062 05/01/2002 5:25 PM
Oly Offline
Jerry, don't go running off on me. Bring yourself and your son on up to the Lounge and "chime" in with everyone. Not enough GMCs on here as is. This place is "addictive" to say the least. That GMC of yours is an excellent way for you and your son ,Lowell, to spend many hours together. I'm certain that Kook can answer quite a few of your questions, but post them here also. Sometimes (which is all the time-LOL) I can't think of the questions I need to ask.-LOL
Welcome aboard.
Oly
The Stovebolt Page Lounge Moderator
p.s.
Send Peggy a picture of your truck for the Gallery
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
