2 members (sron48, Gray_Ghost),
78
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30023 05/06/2003 6:50 AM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | so i was wondering, im a huge fan of the 3 on the tree tranny, but my question is............how can i get good freeway speeds say, 65 or 70 mph at a low rpm without having to throw out that nastolgic 3 speed?
is there any way that i can possibly keep it? all i hear from people is no, is it true? willing to change out almost everything to make it possible as long as i can keep tran. original. any one know how? love to hear anything anyones got to say...........thanx all. -murdoc | | |
#30024 05/06/2003 7:00 AM | Joined: Feb 2003 Posts: 28 Member | | Member Joined: Feb 2003 Posts: 28 | You could throw some higher gears in your rear-end.
Im not sure what year truck you have, etc., but I know mine (51 GMC 1/2 ton) came with 4.11's.
My moms 53 chev also has 411's I think. 55 is pushing it with that truck!
With that being said, you can put some higher gears in your rear end, and achieve those speeds. In the January? Classic trucks, they had an article on this same subject.
Hope this helps,
Dallas
Broccoli is for chopping, classic trucks are for restoring!
-51 102 22 C GMC
#30025 05/06/2003 7:07 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Murdoc, best bet is to get yourself a three speed with overdrive. best thing going. Otherwise you will need a lower ratio rear end.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#30026 05/06/2003 5:02 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | But Oly, isn't it true that to use the 3 speed overdrive you need to have an open driveline? Now you are changing everything.
Short of changing the whole rear end there is only one option. Get a Patrick's 3.55 rear end kit. Still no 70, but 60 would be alright.
54 3100 with 235 62 flatbed dump C60 with 261
