0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I'm trying to replace my front wheel studs with a longer version. Yes, it is to make room for a spacer to make the new 16" wheels fit.
My truck is a 1950 3/4 ton. Anyone know if there is a longer stud than the stock one? If so, what is the part #? | | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Don't have a part number, but, as a suggestion, maybe rear studs from a late model dually might work. I believe they're a little longer, and the same diameter as a 3/4 ton stud. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I replaced my fronts with longer studs. I went to a NAPA with a machine shop. The guy there took care of getting the studs and putting them in. Can't remember the cost but I felt it was a good deal.
40 Chevy 1/2 ton
#3001 12/03/2004 11:44 AM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | | | | | | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | I went down that path with my 54 1/2 ton. Tried NAPA, Autozone, Parts Plus, Pep Boys, you name it. No one had different length studs. Mine were 7/16 diameter and I needed to replace them with 9/16 diameter for new wheels. No one wanted to machine out the hubs while they were on the car. One garage/machine shop offered to do the job for over a grand. I still have my original wheels and tires. Let me know how you fare, and I hope your luck is better than mine.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
| | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I did find longer studs for my truck. I searched through a lot of Dorman parts to find them but think I have two that will work. They are 1/2" in diameter which is original. Email me at [email protected] if interested. | | |
