4 members (Gdads51, Hotrod Lincoln, artinva, RoadsScholar), 62 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#30014 01/14/2004 4:33 PM
Hi,
I located a beautiful complete 261 in an old school bus at the local salvage yard. Yesterday, when I went to clean up the block to get the casting numbers and date, I found a hole the size of Cleveland in the side of the block! eek
Very frustrated, I set out to find another. I found another but it was missing the oil pan. So, can I use an oil pan from a 235? I can't use the oil pan from the first 261 because it is bent where the hole is blown through the lower block. frown
Any and all input appreciated.
Steve
#30015 01/14/2004 7:00 PM
Depends on the 235 and the 261. The 53-55 235 pans are totally different from 55-62 235 pans and wont fit the later 235 engines. There is also a differance in the internal baffles between 55-58 and 59-62 235 oil pans. Some massaging of the oil pan floor was needed to make a 57 pan work with my 58-62 oil pickup. 261 engines may have similar pan differances.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#30016 01/16/2004 9:14 PM
My 59 261 has an oil pan from a 56 235 car engine, fit on no problem in my case.Most 261's have a swiveling oil pick up, be safe and check the clearance of the pick up from the oil pan floor.Mine is about 1/2 inch clearance, works just dandy.
#30017 01/16/2004 9:18 PM
The swiveling oil pump pickup was used on the 55-57 235 engines. I had to massage the 57 'swivel' pan to work with the '60 fixed style 235 oil pump pickup
