| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29963 05/23/2003 7:08 PM | Joined: Apr 2003 Posts: 24 Junior Member | | Junior Member Joined: Apr 2003 Posts: 24 | Does anybody know what number AC plug fits a 1948 chevy 216 6 cyl.? thank you in advance. | | |
#29964 05/23/2003 7:46 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 |
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#29965 05/24/2003 1:43 AM | Joined: Apr 2003 Posts: 24 Junior Member | | Junior Member Joined: Apr 2003 Posts: 24 | Thanks Brian but this is a 48 & for some reason it takes the really small plugs, 10mm i think. Thanks again... | | |
#29966 05/24/2003 6:09 PM | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | rimfire, I had the same problem trying to locate a 10mm plug for my 42 pickup. The best plug I have found and the most readily available is an Autolite 3136. You can get them anywhere and they are cheap!
Chris Simmonds 1942 Chevy 3/4 ton | | |
