| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29512 12/20/2004 11:00 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | I just got my reman rochester B single barrel carb from the local NAPA store. Everything looks good except the choke. The one listed for my truck (230 cid)is a manual choke but the one on the new carb (215 cid Pontiac--my engine) is an auto choke. So my question(s) is: 1.If I order another carb for a truck application (230cid) would it be too big for my engine (215cid)? 2.If I wanted to remove this choke and install my manual choke, how hard is it/is it possible? Thanks for any help provided.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!) 1950 Ford 2 door sedan-project
#29513 12/22/2004 3:53 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | Anyone???? :confused: :confused:
#29514 12/22/2004 6:59 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The carb should work on your 215. If anything, the trucks were under-carbed. Drive it for a while then check your plugs. if they're carboned up, rejet the carb. As far as swapping chokes, I don't think you can do it. I would run the auto choke. I'm assuming it's one with a heat tube, which runs down to the exhaust manifold.
When you ordered the carb, did you tell them you wanted a manual choke? If so, take it back.
Fred 52 3600 69 C-10
