| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 12 Junior Member | | Junior Member Joined: Apr 2004 Posts: 12 | I hope this isn't too stupid of a question, but I've got a replacement set of rocker arms to install on a 1955 1st 235 truck. It does have hydraulic lifters and the books I have tell me that once the engine is a operating temp. to back the adjusters off until they raddle and then tighten them 1/4 at a time until 1 full turn is made.
What I don't know is how to adjust them at first when the engine's cold. Or if the 1 full turn is even correct
Help??????????????????
Ryan
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | To get the engine started, with the cam setting so the valves for a cylinder closed, turn the adjuster to the point where the pushrod doesn't turn. The one full turn will work. Many people only go with 3/4 of a turn.
Fred 52 3600 69 C-10
