1 members (Peggy M),
134
Mod | | | Forums66 Topics128,271 Posts1,058,414 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29504 11/08/2002 4:04 PM | Joined: Nov 2002 Posts: 10 Member | | Member Joined: Nov 2002 Posts: 10 | My 216 packed it in and I am taking this opportunity to swap it for a 235 (46 GMC). A friend of a friend gave me an engine that appears to be very similar to the 216. The casting number, #2135412, comes up as a 248,270. Is this a 248? or a 270? My second question - The 216 flywheel was held on with 6 bolts and this other engine uses only 4 bolts - Is there an adapter available? or should I be looking for another engine?
46 GMC
#29505 11/08/2002 4:16 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | The 228,248,270 GMC engines are better, but totally different than the Chevy engines of the same era. You should find a '55-'62 235, as it will be an almost drop in replacement.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#29506 11/11/2002 1:23 AM | Joined: Jan 2001 Posts: 30 Member | | Member Joined: Jan 2001 Posts: 30 | I agree with Chiphead in that I have a 54 235 in my 46 Chevy, and it is easy to get parts & runs like a champ-- | | |
#29507 11/11/2002 1:42 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | GMC and Chevs have diff #'s. You sure you had a 216 in that GMC?? GMC also has the engine size in first three numbers of serial stamped behind distributor on machined angle surface. Keep in mind 216 is shorter than the 235 late and GMC engines. May need to do radiator mods or undo mods done to yours to put in Chev engine in first place! Even the front motor mount is diff at x-member from GMC and Chevs. GMC is better engine too. :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#29508 11/11/2002 3:25 AM | Joined: Nov 2002 Posts: 10 Member | | Member Joined: Nov 2002 Posts: 10 | This is where it gets interesting - After looking at lots of ID #'s, and not finding mine, I've sort-of determined that it is a 216.
The punched number on the plate just behind the distributor has the number C432317 and the cast numer, on the other side,is 3695451.
The transmission has the number "8 GM 590474" on the left side. Any help on this is also appreciated.
Thanks for the reply's
46 GMC
#29509 11/11/2002 11:03 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I believe canadian GMC 1/2 ton trucks had 216's
