3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#29402 06/28/2002 3:04 AM
Hi all,
I have a 1936 207 with a bent push rod that will not come out. Do you have to remove the side cover to get a push rod out? I don't know why the push rod bent but it has a good bow to it and I have a slight miss that I attribute to it. It is the #2 intake and the valve is moving normally. I have moved the rocker over and pulled with no luck, is the push rod held in with a retainer?
The engine seems to be rebuilt; it has red valve springs and is very clean. Also could some body give me valve lash for this engine?
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck
1970 Mercedes 280SE 3.5 coupe
1987 Mercedes 560SEC supercharged
1989 Mercedes 300CE 5.0 M119
#29403 06/28/2002 3:23 AM
Oly Offline
Steve, Yes, you must remove the side plates, as I recall there are spring retainers holding them in place and they are fastened to the engine. The tappet clearance "HOT" is- Intake,.006-.008 , Exhaust, .013-.015. I do wonder what caused the pushrod to bend thus. This could turn into another book.-LOL
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#29404 06/28/2002 3:47 AM
Thanks Oly,
I have the same thoughts, other than this the engine runs great. I have a 12 volt battery and alt in the truck and she starts every time in 2 turns or less. The idle is very smooth and temps and pressure are right where they should be. I am thinking someone tightened that valve too much, or at least I hope it is that simple
Thanks again, grin
Steve Lemberg
#29405 06/28/2002 4:12 AM
Oly Offline
Steve, I will email you this also if I miss you on here. I just remembered- those lifters come out in groups of six, I think. So you may have to loosen some more rockers. If you need some help on re-assembly, I can help you on that end.
Oly in Oregon
Rest in Peace
1953 Willys CJ3B
#29406 06/28/2002 4:21 AM
Steve , a couple of times , in my youth wink , when I gave the hot 216 in my '39 the big rev eek It bent the odd pushrod or two grin grin
#29407 06/28/2002 4:34 AM
Dusty told me that he solved the bent push-rod problem by using splints,the type used for when a person gets a broken finger. grin :p
Sort of like a crutch for `45 GMC COE trucks grin grin grin
#29408 06/29/2002 4:26 AM
Thanks to one and all,
I had to straighten two push rods and go over several other issues but she made it! I had to fix the parking brake lever and both rear cables, someone did a bit of shade tree engineering. I had a leak at the oil pressure gauge and I put tail lights and mud flaps on for the drive.
Steve Lemberg
