| | | Forums66 Topics128,026 Posts1,055,410 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29402 06/28/2002 3:04 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Hi all,
I have a 1936 207 with a bent push rod that will not come out. Do you have to remove the side cover to get a push rod out? I don't know why the push rod bent but it has a good bow to it and I have a slight miss that I attribute to it. It is the #2 intake and the valve is moving normally. I have moved the rocker over and pulled with no luck, is the push rod held in with a retainer?
The engine seems to be rebuilt; it has red valve springs and is very clean. Also could some body give me valve lash for this engine?
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck 1970 Mercedes 280SE 3.5 coupe 1987 Mercedes 560SEC supercharged 1989 Mercedes 300CE 5.0 M119
#29403 06/28/2002 3:23 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Steve, Yes, you must remove the side plates, as I recall there are spring retainers holding them in place and they are fastened to the engine. The tappet clearance "HOT" is- Intake,.006-.008 , Exhaust, .013-.015. I do wonder what caused the pushrod to bend thus. This could turn into another book.-LOL
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#29404 06/28/2002 3:47 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Thanks Oly, I have the same thoughts, other than this the engine runs great. I have a 12 volt battery and alt in the truck and she starts every time in 2 turns or less. The idle is very smooth and temps and pressure are right where they should be. I am thinking someone tightened that valve too much, or at least I hope it is that simple Thanks again,
Steve Lemberg
#29405 06/28/2002 4:12 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Steve, I will email you this also if I miss you on here. I just remembered- those lifters come out in groups of six, I think. So you may have to loosen some more rockers. If you need some help on re-assembly, I can help you on that end.
#29406 06/28/2002 4:21 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Steve , a couple of times , in my youth  , when I gave the hot 216 in my '39 the big rev  It bent the odd pushrod or two  | | |
#29407 06/28/2002 4:34 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Dusty told me that he solved the bent push-rod problem by using splints,the type used for when a person gets a broken finger.  :p . Sort of like a crutch for `45 GMC COE trucks
#29408 06/29/2002 4:26 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Thanks to one and all,
I had to straighten two push rods and go over several other issues but she made it! I had to fix the parking brake lever and both rear cables, someone did a bit of shade tree engineering. I had a leak at the oil pressure gauge and I put tail lights and mud flaps on for the drive.
Steve Lemberg
