1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29395 11/23/2003 5:35 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | With all the postings about changing a 51 front axle to a 53 on the half Ton, is this as simple on the 1 Ton ? This would be a great thing to know if it were a direct swap. | | |
#29396 11/23/2003 3:10 PM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | trukernix I am just pulling my front axle of the truck. If you need I can take the measurments and pos them. | | |
#29397 11/23/2003 4:39 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Fritz, that would be very helpful. Is yours a 1 1/2 Ton ? I would be interested in the width between perches and maybe center to center on the kingpins.
Thanks, Fred | | |
#29399 11/24/2003 12:25 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | TooManny, what I am thinking about doing some day is replacing my front 1 Ton 1951 brakes withthe 53 1 Ton brakes. That way I can buy drums when needed. | | |
#29400 11/24/2003 5:03 PM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Can you just change the Backing plates? Or are the spindles Different sizes?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#29401 11/24/2003 7:16 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Brian, that is what I am trying to find out. This is a known exchange for the 1/2 Ton but I don't know if the 1 Ton's backing plates can be interchanged from 53 to 51. My concern is that I will get it on the road someday, and as soon as 1 front drum gets scored or whatever, I will have to park it. With the 53, the drums are available new. | | |
