0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#29390 04/23/2004 1:46 PM
My tranny on my 51 GMC leaks oil. The worst leak is at the rear end of the tranny, around the shaft.
Is there a way to fix the leaks without dropping the transmisson? I tried tranny stop leak but I guess the leak is to much for the stop leak.
#29391 04/23/2004 2:33 PM
Jerry,
1/2 ton ? 3 or 4 speed ? Enclosed driveline?
Craig
#29392 04/23/2004 4:01 PM
1/2 ton 3 speed with enclosed drive shaft.
#29393 04/24/2004 2:50 PM
Jerry,
Sorry for late reply. Your original description of where it's leaking is still to vague for me to visualize.
Around the shaft-Are you saying where the driveline connects to the tranny? Can it be possibly the Bell housing gaskets? Or do you really feel the leak is coming directly from the tranny itself. If the latter then how about getting a tranny gasket kit, drain the tranny and replace basically all possible gaskets without having to remove the tranny. This would require you to disconnect the driveline and ujoint. So you can at the same time replace the ball joint various gaskets.
My tranny's top plate and rear ball housing sections were leaking so while I had my rear end torn apart, I replaced as many tranny gaskets as possible short of removing the tranny.
Here's some pics of my tranny, etc. Click on the upper right arrow to review other pics of this folder.
http://community.webshots.com/photo/111968325/111973863JUYEbB
Craig
#29394 04/26/2004 1:17 PM
Thanks Craig,
That was very informative. I have a good idea of what I have to do now.
