3 members (Gray_Ghost, Scott, 1 invisible),
81
0
Mod | | | Forums66 Topics128,050 Posts1,055,761 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29390 04/23/2004 1:46 PM | Joined: Nov 2002 Posts: 9 Member | | Member Joined: Nov 2002 Posts: 9 | My tranny on my 51 GMC leaks oil. The worst leak is at the rear end of the tranny, around the shaft. Is there a way to fix the leaks without dropping the transmisson? I tried tranny stop leak but I guess the leak is to much for the stop leak.
#29391 04/23/2004 2:33 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Jerry, 1/2 ton ? 3 or 4 speed ? Enclosed driveline?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#29392 04/23/2004 4:01 PM | Joined: Nov 2002 Posts: 9 Member | | Member Joined: Nov 2002 Posts: 9 | 1/2 ton 3 speed with enclosed drive shaft.
#29393 04/24/2004 2:50 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Jerry, Sorry for late reply. Your original description of where it's leaking is still to vague for me to visualize. Around the shaft-Are you saying where the driveline connects to the tranny? Can it be possibly the Bell housing gaskets? Or do you really feel the leak is coming directly from the tranny itself. If the latter then how about getting a tranny gasket kit, drain the tranny and replace basically all possible gaskets without having to remove the tranny. This would require you to disconnect the driveline and ujoint. So you can at the same time replace the ball joint various gaskets. My tranny's top plate and rear ball housing sections were leaking so while I had my rear end torn apart, I replaced as many tranny gaskets as possible short of removing the tranny. Here's some pics of my tranny, etc. Click on the upper right arrow to review other pics of this folder. http://community.webshots.com/photo/111968325/111973863JUYEbB
#29394 04/26/2004 1:17 PM | Joined: Nov 2002 Posts: 9 Member | | Member Joined: Nov 2002 Posts: 9 | Thanks Craig, That was very informative. I have a good idea of what I have to do now.
