5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#29365 12/12/2002 12:09 AM
How would you go about testing an ignition coil to see if it works or not? My truck will not start at all, and I checked everything and now im down to the coil. thanks! smile
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#29366 12/12/2002 12:20 AM
If the coil is in the truck. Pull the high voltage wire from the center of the dist. cap. Hold the end near the block and have some one crank the engine. It should spark over half an inch away. If it has no spark or just a small spark it's shot. Careful how you hold the wire or you will get shocked. If it's out of the truck. Most parts stores will test them.
if it dosen't need fixed, break it
#29367 12/12/2002 3:14 AM
I like to do it by flicking the points open with a screwdriver, then you know if the whole system is working or not. Check your wire from the points to the coil to make sure it isn't grounded out.
Paint & Body Shop moderator
#29368 12/12/2002 3:59 AM
I think the test I read looks for a spark that will jump 1/4" in air.
1951 1 Ton Completed
#29369 12/12/2002 4:27 AM
Some months ago I had my truck quit and I started with the basics; fuel, coil, pionts ect. and still had a truck that wouldn't start. Ended up being the rotor. The end that presses against the cap was a rivit and the moisture thru the years made it rust and wouldn't let the spark travel to the plugs... Just a place to look.
Good luck!
Thomas Mott
1949 GMC 250
1957 Dodge COE c-700
1959 Chris Craft 17' w/big journal 327 for more power
