1 members (mick53),
70
Mod | | | Forums66 Topics128,043 Posts1,055,614 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29353 03/24/2003 5:21 AM | Joined: Feb 2003 Posts: 24 Junior Member | | Junior Member Joined: Feb 2003 Posts: 24 | Having not located a pressurized 235 to replace my 235 dipper, one friend said I'd be way better off finding a 250 instead. Anybody done this swap out? Thoughts? (It's actually for a '53 Belair/3sp).
The money I save as a mechanic, I spend on medical bills!
#29354 03/24/2003 8:21 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Jim, It is easier to install a v- motor than a 250, because the 250 is at least 3" longer than a 235. There are plenty of them up here in portland. You might also look for a 261 out of a 2-ton truck or school bus.
#29355 03/24/2003 8:24 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I wouldn't do it. Nothing about how the 250 mounts is the same; motor mounts, bellhousing, clutch link, radiator-water pump clearance. Surely there's a good 235 in your area! Good luck.
Professional Novice
#29356 03/24/2003 9:43 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Stick with the 235 you have found. If you REALLY do not like it, then you can always re-sell it and put in a small-block chevy
#29357 03/24/2003 10:21 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Sounds to me like you need a new friend.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#29358 03/25/2003 9:48 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It is possible, but a lot of work. The 250 block is slightly longer, but narrower, and uses side mounts and a cross-member under the tranny. So, you get to weld up some motor mounts, fab or modify a cross-member for the tranny, and put in an electric fan since you won't have room for the standard fan. Also, the clutch linkage changes.
I'm having a hard time believing that you can't find a good 235 block, around here you could get one in a day. Can some of you Oregon bolters help Jim out on this?
Fred 52 3600 69 C-10
#29359 03/25/2003 10:13 PM | | Anonymous Unregistered | | Anonymous Unregistered | Southern Oregon . . . I was just given a "free" 49 5-window in southern Oregon with a 235 in it . . . all beat to crap, but it is a runner and driver and the price was right! Put the word out that you are interested in getting any old chevy truck parts - people know I am somewhat insane when it comes to old chevy trucks and I am always having people ask me if I want one that they have. . . I bet if you posted an ad in the local classifieds you would be over run with 235's within a few months!  | | |
