9 members (warlock, Otto Skorzeny, 55shaker, k2handyman, RoadsScholar, Ponchogl, 5 Window 9434, 6inarow, 1 invisible), 97 guests, and 2 robots.
Topics128,048
Posts1,055,626
#29353 03/24/2003 5:21 AM
Junior Member
Junior Member
Having not located a pressurized 235 to replace my 235 dipper, one friend said I'd be way better off finding a 250 instead. Anybody done this swap out? Thoughts? (It's actually for a '53 Belair/3sp).
The money I save as a mechanic, I spend on medical bills!
#29354 03/24/2003 8:21 PM
Jim,
It is easier to install a v- motor than a 250, because the 250 is at least 3" longer than a 235. There are plenty of them up here in portland. You might also look for a 261 out of a 2-ton truck or school bus.
Paint & Body Shop moderator
#29355 03/24/2003 8:24 PM
I wouldn't do it. Nothing about how the 250 mounts is the same; motor mounts, bellhousing, clutch link, radiator-water pump clearance. Surely there's a good 235 in your area! Good luck.
Professional Novice
#29356 03/24/2003 9:43 PM
Stick with the 235 you have found. If you REALLY do not like it, then you can always re-sell it and put in a small-block chevy grin
#29357 03/24/2003 10:21 PM
Sounds to me like you need a new friend.
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#29358 03/25/2003 9:48 PM
It is possible, but a lot of work. The 250 block is slightly longer, but narrower, and uses side mounts and a cross-member under the tranny. So, you get to weld up some motor mounts, fab or modify a cross-member for the tranny, and put in an electric fan since you won't have room for the standard fan. Also, the clutch linkage changes.
I'm having a hard time believing that you can't find a good 235 block, around here you could get one in a day. Can some of you Oregon bolters help Jim out on this?
Fred
52 3600
69 C-10
#29359 03/25/2003 10:13 PM
Anonymous
Unregistered
Anonymous
Unregistered
Southern Oregon . . . I was just given a "free" 49 5-window in southern Oregon with a 235 in it . . . all beat to crap, but it is a runner and driver and the price was right! grin
Put the word out that you are interested in getting any old chevy truck parts - people know I am somewhat insane when it comes to old chevy trucks and I am always having people ask me if I want one that they have. . . I bet if you posted an ad in the local classifieds you would be over run with 235's within a few months! smile
