1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29288 10/16/2002 3:08 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Can anyone give me direction in removing and replacing the threaded bushings on the front of the frame for the front springs and the rear of the frame for the rear springs. Is there a tool available for this? I can press the ones out of the spring eye but I can't figure out how to get them out of the frame. Thanks for any input. | | |
#29289 10/16/2002 4:43 PM | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | I tackled this a couple of months ago using Harbor Freight's 3-in-1 Service Kit. Here is the write-up on my website: Frame Job: The beat goes on Boyo (Moderator of this forum) has a homegrown solution he has posted here at stovebolt.com that several have used with sucess: D-I-Y Bushing Puller | | |
#29290 10/16/2002 5:07 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Larry, when you say your rattle can clogged up, have you tried changing the valve with one from another can? Or does the can itself clog?
What is necessary between uses is to hold the can upside down and giving a blast until it runs clear. This clears the valve. I usually just do this as my final swipe over the project I just painted. This way my cans rarely if ever clog.
54 3100 with 235 62 flatbed dump C60 with 261
#29291 10/16/2002 6:19 PM | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | Hey Tony, When I get a clog, I usually try another nozzle before I give up on the can. In this particular case it happened in the midst of a painting operation. This happens all too often with "thick" paints that are only marginally suitable for rattlecans - Eastwood's "Rust Encapsulator", "Chassis Black", "Self-etching Primer", etc. One time, in a hurry, I struck the stubborn cap of a can on the edge of the workbench to get it off - the cap came off but the action also broke the nozzle off, leaving a little bit of the nozzle still down in the can. I thought about going after the nozzle bit with a pair of tweezers for about two seconds until I visualized what I would look like with a painted face  | | |
#29293 10/16/2002 7:21 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | LAROKE: Thanks so much for you post. I'll get the part for Boyo's puller this evening. I can't find the 3 in 1 Service Kit listed in Harbor Freight. Does it have any other name that they might list it under? I enjoy your ongoing journal of Billy Bob's resto. Keep up the good work. I've got a 49 1/2 ton down to the frame starting the rebuild now. Will probably need more advise as it progresses. rwise | | |
#29294 10/17/2002 12:05 AM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Couple suggestions - I have found copious amounts of heat, and a large sledge hammer, help for even the most rusted bushings.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
