8 members (Wickedbass, NJC, GRNHydra, Gone, hdgeren, Otto Skorzeny, rfs56trk, Peggy M),
68
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29220 05/23/2004 12:43 AM | Joined: May 2004 Posts: 2 Junior Member | | Junior Member Joined: May 2004 Posts: 2 | HELP HAS ANYONE HAVE INFO ON GETTING MORE SPEED FOR THE 3/4 TON PU 49 LATE MODEL | | |
#29221 05/23/2004 3:19 AM | Joined: Jul 2001 Posts: 14 Junior Member | | Junior Member Joined: Jul 2001 Posts: 14 | Old 49er,
Welcome to Stovebolters! If you are trying to keep it more like original you have a couple of things you can do. If the old 16" wheels have been replaced with 15" you can pick up a little speed by putting the correct wheels and tires back on. This makes it set higher and I guess it does't look as "cool" by today's standards.
Another improvement would be a rearend swap. You can stay "original" if you can find a '54 rearend. Your '49 has a 4:11 and the '54 has a 3:90 but still has the enclosed driveshaft.
Another option is new gears (Patrick's etc.) which is expensive and should be done by a pro.
Remember, the old AD's weren't exactly built for high speeds. Make sure your brakes are in very good working order and your doors won't "bump" open. I put seatbelts in my '52.
Good luck!
Jim
'52 Chevy 5-window 1/2 ton PU '52 Chevy short school bus
#29222 05/23/2004 4:41 PM | Joined: May 2004 Posts: 2 Junior Member | | Junior Member Joined: May 2004 Posts: 2 | THANKS JIM TIRES ARE 16" IM JUST TRYING TO GET AROUND 65 MPH IM PUSHING AROUND 50 NOW WITH A 235 DO YOU FILL THE 3:90 REAR END WILL PUT ME IN THAT BALL PARK | | |
#29223 05/23/2004 5:00 PM | | Anonymous Unregistered | | Anonymous Unregistered | You presently have a 4.57 or optionally a 5.14 rearend ratio in a 3/4 ton. The kook has a good writeup on a swap that will get you a little more speed. If you can presently do 50mph with a 4.57 (which sounds about right) you will be able to do 55mph with a 4.11 running the same engine revs or if you buy a 3.90 kit (I believe sold by Randy's Ring and Pinion) you will be able to do 58 mph. | | |
#29224 05/24/2004 4:01 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Patrick's gears are for the 1/2 ton. Randy's Ring & Pinion no longer has the 3.90 gears. About the only way to go is with the pumpkin swap described by Kook.
Fred 52 3600 69 C-10
#29225 06/04/2004 3:42 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Anyone out there have a 67-72 rear end I could put in my 1950 truck? I haven't found one locally yet. | | |
#29226 06/04/2004 4:31 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | If your truck still has the torque tube rear end, the swap is more difficult. This is cuz you've got to mount the newer R/E to the suspension, find/cut down a driveshaft and convert the tranny to use an open driveshaft. Lots of info here on the swap.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#29227 06/04/2004 4:59 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by Michael Kamer: Anyone out there have a 67-72 rear end I could put in my 1950 truck? I haven't found one locally yet. Here are some possibilities. 1. Put an ad in the swap meet on this board. 2. Go to the 67-72 parts board . Put an ad there or search for Teeitup, he lives in Meredin (north of Topeka). He parts out trucks, I had him look for one for me. Took a few months, but I got one. 3. Contact Tom Myers, Miami, OK 918-542-3871. He might have some pumpkins.
#29228 06/05/2004 4:26 AM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | What is a torque tube rear end? I assume the truck to be an all original 1950 3/4 ton. | | |
#29229 06/05/2004 5:20 AM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | MK-
Welcome to the Stovebolt. Good question.
If the truck is indeed an original '50 3/4 ton, the driveshaft is enclosed between the transmission to the rear end U joint within a steel tube/pipe known as a torque tube. Later models (after '55 I believe, but certainly by '57) had a single steel drive shaft. Others may correct the details here, but the '50 vintage truck had a unique driveshaft set up. It will be straightforward to upgrade to a steel shaft if you are swapping out the rear end.
Does this help? | | |
#29230 06/05/2004 2:18 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I'll look again but I don't recall seeing anything but a ordinary drive shaft. | | |
#29231 06/05/2004 4:03 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | MK-
The torque tube may look a driveshaft to you, but it is a shaft within a tube. Look at the U joint ends to see if the shaft is enclosed. Alternatively, someone ha already made the swap and you have a standard driveshaft. That would be good news in this upgrade. | | |
#29232 06/05/2004 10:03 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | OK, I just looked it over. Please pardon my ignorance on these old trucks. I'm new to this vintage.
The shaft is in two pieces. In the middle, there is a mounting to the frame. I assume some sort of carrier bearing or something (leaking by the way). The front half of the drive shaft from the tranny to the bearing is enclosed because I see no u-joints. From the bearing to the differential, I see a regular drive shaft with u-joints.
Can you tell me what this is? Is this original? | | |
#29233 06/05/2004 10:14 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The last time that I talked to Randy's Ring and Pinion, I was told that they still have a 4.10 gear set but not the 3.90 set. I don't know if it was good information or not. Anyway, these gears only fit into the more modern 67 to 72 assembly, not the 1950 assembly. The more modern assembly is a boltin. | | |
#29234 06/06/2004 4:44 PM | Joined: Jan 2004 Posts: 32 Junior Member | | Junior Member Joined: Jan 2004 Posts: 32 | All of the books I have (1951) state that the torque tube drive train is only on the 3100 series 1/2 ton trucks. I have a '51 3604 Chevy Pick up with a 4 speed and 4.57 ratio full floating rear axle. Other than a '57 235 engine and newer rims the truck is original. I installed a set of 7.50 16 bias ply tires on rims from a 95 chevy 3/4 ton truck. I can cruise at 65, and the 8 ply tires hold 60 psi, I keep 45 psi in the tires and it makes for a fair ride and easy steering.e | | |
#29235 06/07/2004 12:39 AM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Well, where does that leave me for an upgrade in rear end gear ratio? Can I swap out with a 67-72 c20 pickup? Do I need to find new ring and pinions?
Based upon what I said in my previous post, do I have an torque tube or is this considered an open drive shaft?
Any help is appreciated. | | |
#29236 06/07/2004 3:09 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Mike - From your description you have the stock 3/4 ton driveline. Front portion of the driveshaft is enclosed, rear portion is open. To upgrade your gears, you need the pumpkin (center section) from a 64-72 with a ten bolt full-floating differential with 4.10 gears. The swap is fairly easy, but it does take two people, due to the weight of the pumpkin and the location. Follow the instructions from Kook, and you'll be okay. The most difficult part is locating a differential.
Do you have a factory service manual? If not, you should get one from one of the vendors, cost is about $30. It will be the best tool that you can buy, has instructions on how to repair almost anything on these trucks.
#29237 06/07/2004 8:37 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Thank you. I do have a manual and it has been helpful. Do you know if there are other ratios produced such as a 3.90 where I could purchase the ring and pinion and have them put in? Do you think it'll make that much difference? If not, I would much rather get a used 4.11 since it will be easier. | | |
#29238 06/08/2004 9:01 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Can anyone tell me how to identify the ratio of the rear end? | | |
#29239 06/09/2004 4:47 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Yes, "Jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 & 3/4 turns, you probably have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading." (quoted from West Coast Differentials)
*** GMC ***
#29240 06/20/2005 3:44 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I'm considering the possibility of swapping the original torque tube rear end in my '51 3100 for another torque tube rear end from a passanger car from the same era with better gearing. Does anybody have any suggestions of which years/models I should look for?
#29241 06/20/2005 6:21 AM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Michael,
I have a '53 3/4 ton- originally 4.57:1 rear end. I put in a "pumpkin" from a '72 Chevy 3/4 ton van with 4.10:1 gearing. It took about half an hour with a good helper. Make sure your donor pumpkin is the higher gear ratio by counting the revs. Mine was marked but I turned it anyway before installing just to make sure. Find a junk yard that does 60's-70's Chevy trucks. I paid $250 for mine- well worth it. I can easily do 65 mph with my '54 235 and stock 4-speed. Good luck. Tyler | | |
#29242 06/20/2005 7:58 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | No portion of a stock 3/4 or 1-ton driveline is enclosed on a '47.2-'55.1 truck, at least on any I've ever seen. | | |
#29243 06/20/2005 8:02 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | $250??? I paid about $60 at the local pick-n-pull for my 4.10 open pumpkin. | | |
#29244 06/20/2005 6:58 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Michael, there are a few ways to indentify the gear ratios. One way is described above. If you pull the rear diff cover, on the end of the pinion shaft you will see a series of numbers. The ones you car about will have a hyphen "-" between them which describe the number if pinion and ring gear teeth. These are what determine the ratio. For example, you might see "GM-7-32". This indicates 7 pinion teeth & 32 ring teeth for a ratio of 32/7 or 4.57. It's a good idea to count teeth on each just to be sure. I'm just in the process of finishing my swap-I'm painting the diff cover and looking forward to seeing the difference in the high end speed. The swap is very easy if you have a rolling floor jack to carry the new gears-I didn't even have to jack up the truck. Make sure that your pinion seal is in good shape. For $13.00, now's the time to replace it. | | |
#29245 06/20/2005 8:41 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by GMCpanel: No portion of a stock 3/4 or 1-ton driveline is enclosed on a '47.2-'55.1 truck, at least on any I've ever seen. I had a '47.2 3/4-ton a year ago. It had an enclosed driveline the first few feet back from the transmsission, and was open from the end of the tube to the differential. I've just acquired a '52/'53 1-ton and need to look under it soon.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#29246 06/21/2005 1:58 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | I did the 457 to 411 swap on the 51 chevy 3/4 ton I was told that 67 to 72 suburban with automatic and big block 400 some came with a 373 rear end I found one but guy would not part with it they are very hard to find. good luck | | |
#29247 06/21/2005 4:10 AM | | Anonymous Unregistered | | Anonymous Unregistered | This is only gor 3/4 tons though right? is it possible to take the tube/driveshaft off of a 3/4 ton, shorten it and put it in a half ton? I also aquired a 52 3/4 ton this weekend and have yet to check what it has. Thanks. | | |
#29248 06/21/2005 5:24 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Oldsub, I know my '52 and '54 1-tons have exposed u-joints at the back of the transmission. | | |
