1 members (Ridgeback),
42
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29188 05/01/2003 1:11 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The lines to and from the engine into the filter are small diameter hydraulic lines. I do not care to follow the instructions of plugging, drilling, and tapping the holes in my block to convert my filtration system to full flow, if I do not have to. So, I am trying to find the largest diameter lines to increase the current 20% filtration system.
Yesterday, I read the conversion from the 20% filtration to full flow as described by Phat. His article showed to use copper. I have previously asked about fuel lines but was told the lines are not acceptable. I do not know why but either fuel lines clog or deteriorate.
Does everyone out there use the lines either from one of our friendly venders or what? Is copper an option? Or do you put on a male end and use hydraulic line with a hose clamp?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
#29189 05/01/2003 2:32 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | One problem that I see that will happen is that you will reduce the flow of oil going to the engine. Remember, this is a bypass system, and that when more oil that goes through the filter, the volume and pressure of oil going to your bearings and valve train will be reduced unless you're also installing a high volume oil pump.
Fred 52 3600 69 C-10
#29190 05/01/2003 5:35 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Fred,
Thanks. I didn't think about that. I forgot this is an add-on, a by pass system. I guess I will get out the books and see who sells the lines.
Thanks again,
#29191 05/21/2003 7:08 PM | Joined: Jun 2001 Posts: 27 Member | | Member Joined: Jun 2001 Posts: 27 | Did you find any out there I need new ones for my truck too....????? | | |
#29192 05/21/2003 7:45 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Take the lines to your parts store. They should be able to match them. If not, they can tell you where to go to get some made locally.
#29193 05/21/2003 7:48 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | When I got my 49 some one had already change over from the original lines to what I have now. However shortly after getting the engine started I found that one line was damaged.
The lines that I used are plastic semi transparent and felible. They are used in conjunction with brass fittings made by a conpany called Swedge lok (sp?). So far I have no complaints and it is nice to see the lines have oil going thru them.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
