| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | lectronic injected trottle body carb. Stomp on it from stop idle spits out of carb and then goes. I us ethel and got msd6a. Probably timing huh? Gracias in advance, Kip
Write On The Cross At The Head Of My Grave To Whiskey And Women Here Lies A Poor Slave
| | | | | Joined: Feb 2002 Posts: 21 Member | | Member Joined: Feb 2002 Posts: 21 | Kip, Make sure you haven't got ANY airleaks on the induction side between air filter and throttle bottle. It will make the TBI play up to thinking it needs more gas than the engine really needs. Bob | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Your O-2 sensor could also be making it run a little to the rich side,,,,,
