1 members (baldeagle), 108 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#2907 07/15/2002 3:39 AM
Kip
Offline
lectronic injected trottle body carb. Stomp on it from stop idle spits out of carb and then goes. I us ethel and got msd6a. Probably timing huh?
Gracias in advance, Kip
Write On The Cross At The Head Of My Grave
To Whiskey And Women Here Lies A Poor Slave
#2908 07/15/2002 6:57 AM
Kip,
Make sure you haven't got ANY airleaks on the induction side between air filter and throttle bottle. It will make the TBI play up to thinking it needs more gas than the engine really needs.
Bob
#2909 07/15/2002 7:43 AM
Your O-2 sensor could also be making it run a little to the rich side,,,,,
