5 members (Ponchogl, MickeyP, Bill Marlow, 48jim1ton, 1 invisible), 119 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
#2904 03/29/2005 3:44 PM
8
8 Offline
The shop manual only says to lube the u-joint through the plug in the top of the trans. It doesn't say how much oil to use. When I took it apart, there was only a very little bit. I know it probably shouldn't be full, but I think it should have had more. Anybody know how much it should have? By the way, its a 3 speed. TIA smile
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#2905 03/30/2005 4:23 AM
I think I used about a half cup. It is only to lube the u-joint until the oil in the transmission starts moving. I also lubed up my u-joint before I sealed up the ball housing.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#2906 03/31/2005 8:55 AM
i was going to shoot some grease into mine i figure it will stay there longer
