| | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | The shop manual only says to lube the u-joint through the plug in the top of the trans. It doesn't say how much oil to use. When I took it apart, there was only a very little bit. I know it probably shouldn't be full, but I think it should have had more. Anybody know how much it should have? By the way, its a 3 speed. TIA
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I think I used about a half cup. It is only to lube the u-joint until the oil in the transmission starts moving. I also lubed up my u-joint before I sealed up the ball housing. | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | i was going to shoot some grease into mine i figure it will stay there longer | | |
