| | | Forums66 Topics128,180 Posts1,057,158 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28957 12/19/2002 6:52 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Guys, I have access to a good, inexpensive 250 out of a 196? Chevrolet Nova.
Should I be interested?
Is it a bolt-on in my AD?
I dont need it, but than again (as my wife would say), it never stopped me from buying anything in the past...
whizzerick | | |
#28958 12/19/2002 7:47 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Hey Whizz, long time no see! Hope all is well in La Belle Provence. The later inline sixes (like your 250) aren't a "direct bolt in" for an AD, unfortunately. The main issue is mounting. The later sixes mount to the sides of the engine block and transmission tailshaft just like a smallblock V-8-so you've gotta change the mounting system. I'm sure some other fellas here have pulled this one off and could offer some tips. I read in one of mothertrucker's Gallery submissions that one of his trucks had a later 250 in it-you might want to drop him a PM. Hope this helps, Rick. Wishing you and yours the best of the holiday season, Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#28959 12/19/2002 9:37 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | If it's an early to mid 1960s Nova (through 1967), chances are good that the 250 is actually a 230. Be sure to run the casting #s to make sure you're getting exactly what you pay for.
-ftyler | | |
#28960 12/20/2002 12:30 AM | Joined: Jun 2000 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 15 | Tom Langdon at Stovebolt Engine Co. has weld-in mounts for that application. I don't have his # handy, but there's a link to his website on the banner on the Inliners home page.
< Passin' Side ........ Sui-Side >
#28961 12/20/2002 11:50 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | If you do get it in there, you could make it scream pretty well with some mods. Easier than a 235. If that's your intention of course. | | |
#28962 12/20/2002 6:05 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Whizzer - Like they said, it's not a bolt-in, but shouldn't be that tough. The block is narrower and requires special mounts. I think Landgon's Stovebolt has them. Also, be sure to run the numbers. The early Nova's had a 194 as an option to the 4 banger. The 194, 230 and 250 share the same block. Inliners.org probably has more info, and does have a good number chart.
Fred 52 3600 69 C-10
#28963 12/21/2002 4:35 AM | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | I think the pre-80 250 six is a good motor, for what it is. I had 2 in the past. It seems to be a favorite of the good folks at inliners.org. That's another thing, each website/forum/vendor seems to have a favorite. Patricks loves 235s, and it's real popular here on the 'bolt page. It would be much easier to put in your AD than a 250.
Professional Novice
#28964 12/21/2002 7:56 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | One more thing. If the engine has the integral head/intake manifold, you will want to get a different head and manifold. This was one of those good ideas for less maintenance, but they are not made for performance.
