0 members (),
81
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28775 03/05/2002 8:45 AM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | well, today I was working on my truck, and I just got done putting my tools away etc. Since my truck doesnt have a wooden bed in it, I can see the driveline, axle, and all that other stuff. I saw something wet on the bottom of the tire, and I figured that the brake lines had developed a leak (great!) So, I crawled under the truck and wiped my fingers across the wet stuff. Turns out it is gear oil. I remember when I changed the gear oil in the rear end, that it had not been filled up all the way when I drained it. I figure the axle seals were bad before that, and filling the rear end up all the way allowed the oil to seep through the seals. What does it take to get the old seals out and the new ones in? what kind of locking system holds the axles in? My rear end is a Dana 44 10 bolt. :confused:
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#28776 03/05/2002 8:32 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Here is an exploded diagram: dana 44 exploded view First, you pull the hubs, brake drums, and backing plates. Keep track of the shims that fit behind the backing plates. They hold the wheel bearings in. Then, pull out the axle shafts. This will require a slide hammer. The wheel bearings will come out with the axle shafts. cutaway view The seal is behind the wheel bearing. Replace it and put everything back together the same way it came out.
#28777 03/06/2002 5:48 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Be sure to clean out the air vent on the differential. Usually are plugged, and when the lube gets hot it blows out the seals.
Fred 52 3600 69 C-10
