8 members (Southerntruck, Jon G, GMCJammer51, 3800GUY, Bill Hanlon, Otto Skorzeny, 2-Ton, 50Chevy3100), 157 guests, and 1 robot.
Topics128,102
Posts1,056,185
Members48,436
#28735 03/16/2002 9:17 AM
What's the torque specs on the pressure plate to the flywheel on a 235,with a 3 speed?
Chevyboy
My truck don't leak oil, it just marks its teritory.
For 48-52 Chevy trucks it says 25-30 ft-lbs. It doesn't say there is a difference for 3 or 4 speed. I'd assume that 235's of newer vintage would probably be the same. smile
Thanks Whitelightning,
Also is it easier to reinstall the flywheel, and clutch assembly up through the bottom of the bellhousing by one person? Or is it easier to do this proceedure with 2 people?
Chevyboy
Chevyboy,
You probably know that the flywheel bolt holes are indexed (not equi-distant) so that it goes on one way. Otherwise your timing marks don't work out so good. It's do-able with one person, but the son of a gun gets heavy until that first bolt goes in. Requires at least two GRRRRS of moderate volume. Not much room for two guys.
