Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (jasrking, 216wny, TexasA&M48Truck, MNSmith), 26 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#28731 12/21/2003 6:23 PM
I had the engine rebuilt (235) for my burb 2 years ago and it has sat dry ever since. What do I need to do to fire it up and keep any stupid mistakes to a minimum? eek
#28732 12/21/2003 7:54 PM
If it were mine I would pull the plugs and squirt a little oil in each cyl. If the pan was not filled with oil do it now. I would get some 30 wt HD and a quart of Chevrolet Engine Oil Supplement (EOS). Any chevy parts counter has it. Pull the valve cover and then crank it over til you see oil oil at the rocker arms. Then put it back together and fire it up. Run it at 1500 rpm's for 1/2 hr to break in the cam. Let it cool down and retorque the head bolts,manifold bolts, etc. Fire it up reset the idle, check timing etc. Change oil.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#28733 12/21/2003 10:11 PM
I know there is controversy about whether rings should be oiled or dry for brake in at start up. The new trend is to have the rings and cylinders dry.
I would pull the distributor and spin the pump with a drill motor until you see oil at the rockers.
My Blog
#28734 12/21/2003 11:15 PM
Anonymous
Unregistered
Anonymous
Unregistered
I would be cautious about using any oil additives unless they are specifically designed for break in duty.
Also - don't even try to start it till your burb is ready to drive (brakes work, cooling system road ready, good tires, steering close enough to drive) etc. Ask Tony P how many smokey engines he has seen from "driveway break ins" instead of properly seating the rings by working the motor as prescribed by the ring manufacturers.
Most of all - keep an eye on oil pressure and engine temperature once you do start it up. Don't want to have to rebuild your rebuild any time too soon.
