6 members (bucktruck, dt235sd, Stelonlevo, Hotrod Lincoln, Mike B, 1 invisible), 104 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
Haven't posted much lately but I am back to work on my truck and I need some real stovebolt expertise here!
Anyone out there put a later model bellhousing on a 41-46 chassis crossmember?
My 41 has the nice flat level mounts on the bellhousing but since I am upgrading to a '73 Saginaw 4spd I have to switch to the later bellhousing. I have a bellhousing from a 54 that will work (thanks OldSub!) but it has the angled mounting surfaces and the big funky mounting pads.
Should I:
A. make some kind of adapter?
B. build a new crossmember to use the original mounts?
C. make a new crossmember and use some other type of mounts?
D. chop up an original crossmember from a 54/similar?
bueller? nobody?
oh well yesterday I just decided to cut the stock cross member out and am making a new one.
I drove out to Buffalo Ent. today to get some front end stuff done and learned that a 47-53 x-member would have worked on my stock crossmember! (did not know that) The good news is by swapping out to a 54 and later style housing I can switch to any of the later bellhousings and I may want to throw in a 250/292 anyway.
How about a '50-53 bellhousing? Mine is flat, unlike the '54- up.
Oops, too late, sorry.
Paint & Body Shop moderator
I've ran the Saginaw and now T-5 behind my stock 46 bell housing using an adaptor plate. Heard Buffalo has them (see his ad on inliners.org site) or you can bolt right up a 51 pickup bell housing which the saginaw will bolt to, used same 41 mounts on the sides.
1946 1/2-Ton Chevy
oops sorry
I posted my bellhousing question on the wrong post. Please look at the post on the cluth and disc for my question about the trans and bellhousing dilema.
Geez...what a rookie.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
