1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#28314 10/25/2002 5:14 PM
I am currently doing a ground up on a 51 3800 pickup (chevy) and im now at the point where i have to make some decisions. i am going with a 235, updating the rear to 3.90 and need some advice on what tranny to go with.Any help or advice would be greatly appreciated.
#28315 10/25/2002 7:08 PM
First, what are you going to do with the truck? What kind of driving? Parades, highway, drag strip, bouncing around the pasture?
Fred
52 3600
69 C-10
#28316 10/26/2002 3:24 AM
Anonymous
Unregistered
Anonymous
Unregistered
a one ton truck deserves nothing less than a 4 speed. SM420.
#28317 10/26/2002 5:56 AM
If you are upgrading the rear anyway, can you go more than 3.90?
54 3100 with 235
62 flatbed dump C60 with 261
#28318 10/26/2002 7:50 PM
What's wrong with 3.90's ? I think that's an excellent choice. Beats the heck out of the stock 4.57's, at least for seeing some highway duty. If it's just going to be beating around the property, than just leave the stock gears in.
Just be glad you don't have 6.13's ! eek 3500 RPM at 63 mph with 37" tall tires.
If you know what tires you'll be running, go to this site . That should help clear up your decision.
Good Luck Phil, whatever you decide smile .
*** GMC ***
#28319 10/28/2002 11:05 PM
Not looking to haul any weight at all, mostly, truck will be used as a driver. Is the sm 420 an easy bolt in, or would there be mods?
#28320 10/29/2002 5:54 AM
SM420 is what came in the 3/4 & 1 ton models. Should be a bolt in, except for the closed driveshaft.
While the 3.90 gear is a little low for highway use, there's not much choice unless swap for a late model differential. That can get you 3.73 and 3.42 gears.
Fred
52 3600
69 C-10
