0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28255 01/18/2003 10:27 PM | Joined: Sep 2002 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 62 | I'm in the process of cleaning up and painting the engine on my '53 3100. I'd like to remove the dipstick tube so I can clean it and paint it better and I don't want to destroy it in the processs.
How do I get this tube out? Does it unscrew or is it pressed in?
I can't get any wiggle out of it at all.
Now that I've got the oil pan off can I put a snug fitting punch in the bottom of the hole and tap the tube out from the bottom? | | |
#28256 01/19/2003 12:17 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | I would try to find a rod that will fit snugly in the top of the tube. Then clamp a vise grip around the tube where the rod is and try to twist the tube gently. You can also tap on the bottom of the vise grip with a hammer to help jar in loose.
I would not use a punch on the bottom side. You may mushroom the bottom end and then really have a bad time getting it out. | | |
